Hi, this is Sven from germany and i have a question / problem with VDJScript (using Build 5949 on Win10).
I wrote an action for a Button which is working, but the syntax looks horrible. So i'm looking for a better approach.
What do i wanna do in general?
With one Button on a controller i'd like to
1. reset the eq
2. set the 'filter' to 50%
3. reset all 5 stems back to 50%
4. unmute a stem if it is muted
The action for the first three Commands is easy and working fine:
action="eq_reset & filter 50% & stem 'Vocal' 50% & stem 'Instru' 50% & stem 'Bass' 50% & stem 'Kick' 50% & stem 'HiHat' 50%"
But now Command 4: We have 5 StemCommands to check ( mute_stem 'Vocal', mute_stem 'Instru' and so on) with a possible state "on" and "off" -> so there are 32 Combinations at all to check.
My problem is that the following abstract command doesn't work because as soon as i use the ? Operator for the first time to check a state - the '&' Operator now works only in one of the two expressions from the '?'-switch and not in the "higher" level anymore:
The command what i need is written in abstract form like this:
action = "ResetEQ" AND
"Reset Filter" AND
"Reset5 Stems" AND
"if stem 'Vocal' is muted ? unmute it else do nothing" AND // (4A)
"if stem 'Instru' is muted ? unmute it else do nothing" AND // (4B)
"if stem 'Bass' is muted ? unmute it else do nothing" AND
"if stem 'Kick' is muted ? unmute it else do nothing" AND
"if stem 'HiHat' is muted ? unmute it else do nothing" AND
when i write examplary the Parts 4A and 4B it in that way:
"mute_stem 'Vocal' ? mute_stem 'Vocal' : nothing & mute_stem 'Instru' ? mute_stem 'Instru' : nothing" it doesn't work because the "&" Operator is not interpreted like the "AND" instruction from the abstract command above. It is interpreted as "and" in the 2.Expression from the first "?" operation.
So the only way for me was to program out all 32 possible paths of the 5 mute_stem commands :
eq_reset & filter 50% & stem 'Vocal' 50% & stem 'Instru' 50% & stem 'Bass' 50% & stem 'Kick' 50% & stem 'HiHat' 50% & mute_stem 'Vocal' ? mute_stem 'Instru' ? mute_stem 'Bass' ? mute_stem 'Kick' ? mute_stem 'HiHat' ? mute_stem 'Vocal' & mute_stem 'Instru' & mute_stem 'Bass' & mute_stem 'Kick' & mute_stem 'HiHat' : mute_stem 'Vocal' & mute_stem 'Instru' & mute_stem 'Bass' & mute_stem 'Kick' : mute_stem 'HiHat' ? mute_stem 'Vocal' & mute_stem 'Instru' & mute_stem 'Bass' & mute_stem 'HiHat' : mute_stem 'Vocal' & mute_stem 'Instru' & mute_stem 'Bass' : mute_stem 'Kick' ? mute_stem 'HiHat' ? mute_stem 'Vocal' & mute_stem 'Instru' & mute_stem 'Kick' & mute_stem 'HiHat' : mute_stem 'Vocal' & mute_stem 'Instru' & mute_stem 'Kick' : mute_stem 'HiHat' ? mute_stem 'Vocal' & mute_stem 'Instru' & mute_stem 'HiHat' : mute_stem 'Vocal' & mute_stem 'Instru' : mute_stem 'Bass' ? mute_stem 'Kick' ? mute_stem 'HiHat' ? mute_stem 'Vocal' & mute_stem 'Bass' & mute_stem 'Kick' & mute_stem 'HiHat' : mute_stem 'Vocal' & mute_stem 'Bass' & mute_stem 'Kick' : mute_stem 'HiHat' ? mute_stem 'Vocal' & mute_stem 'Bass' & mute_stem 'HiHat' : mute_stem 'Vocal' & mute_stem 'Bass' : mute_stem 'Kick' ? mute_stem 'HiHat' ? mute_stem 'Vocal' & mute_stem 'Kick' & mute_stem 'HiHt' : mute_stem 'Vocal' & mute_stem 'Kick' : mute_stem 'HiHat' ? mute_stem 'Vocal' & mute_stem 'HiHat' : mute_stem 'Vocal' : mute_stem 'Instru' ? mute_stem 'Bass' ? mute_stem 'Kick' ? mute_stem 'HiHat' ? mute_stem 'Instru' & mute_stem 'Bass' & mute_stem 'Kick' & mute_stem 'HiHat' : mute_stem 'Instru' & mute_stem 'Bass' & mute_stem 'Kick' : mute_stem 'HiHat' ? mute_stem 'Instru' & mute_stem 'Bass' & mute_stem 'HiHat' : mute_stem 'Instru' & mute_stem 'Bass' : mute_stem 'Kick' ? mute_stem 'HiHat' ? mute_stem 'Instru' & mute_stem 'Kick' & mute_stem 'HiHat' : mute_stem 'Instru' & mute_stem 'Kick' : mute_stem 'HiHat' ? mute_stem 'Instru' & mute_stem 'HiHat' : mute_stem 'Instru' : mute_stem 'Bass' ? mute_stem 'Kick' ? mute_stem 'HiHt' ? mute_stem 'Bass' & mute_stem 'Kick' & mute_stem 'HiHat' : mute_stem 'Bass' & mute_stem 'Kick' : mute_stem 'HiHat' ? mute_stem 'Bass' & mute_stem 'HiHat' : mute_stem 'Bass' : mute_stem 'Kick' ? mute_stem 'HiHat' ? mute_stem 'Kick' & mute_stem 'HiHat' : mute_stem 'Kick' : mute_stem 'HiHat' ? mute_stem 'HiHat' : nothing
Wow is that a cumbersome command.
-> Much easier would it be, when there would be in a reset command for all stems (which resets all stems back to 50% AND unmutes a stem if it is muted) analogous to the 'eq_reset' command (which resets all eq_bands AND ALSO resets a 'eq_kill' if it was set -> perfect!). Where can i make such an suggestion - where is the right place for it?
So my final question: Is there an easier syntax to program the abstract command above in VDJ (without programming out all 32 decision-paths)?
Thanks for helping me.
1. reset the eq
"Reset Filter" AND
"Reset5 Stems" AND
geposted Fri 26 Jun 20 @ 10:15 am
And since there are some agregate stems, you could further reduce the script:
mute_stem MeloRhythm off & mute_stem Vocal off
geposted Sun 11 May 25 @ 7:07 am[ selected best answer by locoDog on Tue 13 May 25 @ 2:38 pm ]
Just a hint. Use the [ code ] Tag if you are posting a script.
It makes reading the code much easier.
EDIT: okay, IF the format is better. Maybe its copy&paste problem and not preserving new lines
geposted Fri 26 Jun 20 @ 10:33 am
In a forthcoming update eq_reset will do all of this (except filter).
So you will be able to do:
As always no ETA, but soon ;)
geposted Fri 26 Jun 20 @ 10:47 am
So rather than just resetting the normal EQ, this will reset the stems EQ as well?
What about if the user only wants to reset standard EQ, not stems (or vice versa)? Shouldn't there be a stem_reset as a separate thing?
geposted Fri 26 Jun 20 @ 11:00 am
Thanks! That sounds good! So I'm waiting for it. :)
But in general - is there an easier way to program out commands and multiple decisions? Or do i always have to program out all paths seperatlely like i showed it in the initial-Post??
In Abstract way:
action =
instruction1
AND
if ConditionA Do instruction2 else instruction 3
AND
What is here the best syntax?
geposted Fri 26 Jun 20 @ 11:55 am
"quote=groovindj]
[/quote"
That's true
and what will be the action of setting resetEqOnLoad ?? Shouldn't there be a resetStemOnLoad as a separate thing either?
[/quote"
That's true
geposted Fri 26 Jun 20 @ 1:00 pm
Is there a solo or unsolo or reset stem command ? Im trying this ( deck left stem "FullVocal" & deck left stem FullMelo & deck left stem FullRhythm) to unmute but its not working, what am i missing ?.
geposted Fri 26 Mar 21 @ 1:05 pm
dfyffe wrote :
Is there a solo or unsolo stem command
only_stem 'vocal'
only_stem 'melody'
geposted Fri 26 Mar 21 @ 3:17 pm
Does eq_reset reset all stems now? It doesn't seem to be the case yet...
Or has there since been a btter command to reset everything including stems?
Just looking for an update regarding this issue.
geposted Tue 14 Dec 21 @ 9:53 pm
eq_reset will indeed work and reset the EQ, but it wont reset Stems if you have chosen Classic Eq (No Stems) and try to apply Stems from other buttons or faders (e.g the Stems Pads page)
geposted Tue 14 Dec 21 @ 11:32 pm
Thank you very much, SVENVIRTUAL, for this subject. It helps me, without including equalizer, to reset in one click the stems pads. Very useful.
geposted Mon 02 Oct 23 @ 9:57 am
Reviving an old thread here. Is there now a more simple way to UNMUTE or RESET all stems in one action in 2025?
geposted Sat 10 May 25 @ 9:39 pm
since 2022 with brackets in script BUILD 6883
3 dials & 5 threaded queries, all bases covered
is stem pad on? [is the stem being allowed thru?] Yes do nothing : No toggle the pad so it is on
@devs could this be condensed to a verb?
stem fullmelo 0.5 & stem fullrhythm 0.5 & stem fullvocal 0.5 & ( stem_pad instru ? : stem_pad instru ) & ( stem_pad hihat ? : stem_pad hihat ) & ( stem_pad vocal ? : stem_pad vocal ) & ( stem_pad kick ? : stem_pad kick ) & ( stem_pad bass ? : stem_pad bass )
geposted Sat 10 May 25 @ 10:20 pm
Instead of using stem_pad, you could use mute_stem directly, which accepts on/off
Selected as best answer geposted Sun 11 May 25 @ 7:07 am
This worked. Thanks!
geposted Mon 12 May 25 @ 6:16 pm
