I have auto gain values set in options, but every song is 100% gain and if I do not quicky turn down the channel gain on each deck it literally blows my headphones or speakers out. What could be going on. This is a fellow dj's mixer and I went through all the sound options repeatedly last night. All gain settings are set to a typical vdj setup including autogain. Thanks for any help.
geposted Sat 27 Jun 20 @ 5:53 pm
Hi,
I have DDJ1000 V1.07, no problem about this
geposted Sat 27 Jun 20 @ 6:03 pm
Just to clarify, each song loaded is pegged max gain on the channel, full red. I have to quickly slam the gain to zero and then adjust back to regain the proper volume. It makes for a very stressful dj experience. Imagine if you will that you cannot really do much else than focus on every songs volume levels all night. You cannot even use automix for a bathroom run because the next song loaded will be pegged at max red.
geposted Sat 27 Jun 20 @ 7:42 pm
I am wondering if the asio gain values might be set to a plus db value.
geposted Sat 27 Jun 20 @ 7:44 pm
Hi,
Finally you are right
To much gain with DDJ1000 and even with another audio card -> MOTU 8A or with VIRTUAL CORE AUDIO CABLE :
It's another VDJ problem VDJ 2021 even in early 8.5 V5965 :
see here :
https://www.virtualdj.com/forums/235861/VirtualDJ_Technical_Support/BIG_AUDIO_ENFINE_PROBLEM_-__3dB_between_internal_audio_engine_and_driver_audio_output.html
see here :
geposted Sat 27 Jun 20 @ 11:18 pm
interesting
geposted Sat 27 Jun 20 @ 11:25 pm
my mistake : i've 2X time audio output of my MOTU 8A in BDJ that why the volume was saturated.
Fixed now, no bug at all
geposted Sat 27 Jun 20 @ 11:28 pm
So, a similar thread was posted 9 months ago, but no answers there either
geposted Mon 29 Jun 20 @ 1:11 pm
