Hello Guys Im Running VDJ 2021 on a MacBook Pro I7 quad Core 2.8Ghz 2017 with a raedon Pro 555 2gb and intel Graphics card as well .
I never came across an issue like this in VDJ 2020. I really like the stems feature. its a game changer for me .
I know its a bug because some times I go in the settings and click to "startvideoonload' and it works, its like it unlocks all my video features .
geposted Sun 28 Jun 20 @ 3:48 pm
Did you keep the software updated, been a couple of incremental updates addressing the graphic card used both for stems and video at same time
geposted Sun 28 Jun 20 @ 3:54 pm
yes im running the latest update on both OS and VDJ.
geposted Sun 28 Jun 20 @ 4:00 pm
Do you have experimentalUseMetal enabled?
If so, you should remove SyphonClient from your VirtualDJ plugins folder as it is not compatible with Metal.
geposted Sun 28 Jun 20 @ 4:03 pm
yes I have metal active. how do I remove syphon client from VDJ?
geposted Sun 28 Jun 20 @ 4:13 pm
Go to your documents virtualdj plugins64 videoeffects folder and remove it from there
geposted Sun 28 Jun 20 @ 4:15 pm
Thanks adion that was the issue now it works thank you man!
geposted Sun 28 Jun 20 @ 4:25 pm
