the loaded decals are not displayed correctly in the sidelist and in the automix. Only when you move the mouse over it, the old teeth are deleted and only the current ones are displayed.
Sorry for my google english
geposted Sun 28 Jun 20 @ 5:40 pm
remember
geposted Sun 19 Jul 20 @ 10:04 am
You mean the sort order?
Or the files with red strike over the note icon? (Those are files that no longer exists at the location in the database, in other words you have moved them outside of VirtualDJ, or deleted/renamed the file perhaps)
geposted Sun 19 Jul 20 @ 10:05 pm
wat???
:-O
The "LOADED IN" display is not updated when a new Trak is loaded.
It has nothing to do with sorting !!
It only works if you load the traks with the PC, not with the controller.
geposted Mon 20 Jul 20 @ 12:21 pm
