If I change the BPM of a song is there a way to have that change apply every time I load that song?
Thanks for any advice!
geposted Wed 01 Jul 20 @ 10:53 pm
you can edit bpm in tagedit or bpmeditor to fix it forever
you can add an action poi to set it at firstbeat
but take care of smart bpm setting too
geposted Wed 01 Jul 20 @ 11:07 pm
Your changes are remembered in the database by default.
(and are only ever reset to what it used to be if you explicitly right-click and choose re-analyze)
geposted Wed 01 Jul 20 @ 11:13 pm
I think he means he wants to play a song faster or slower than its original BPM (i.e. change the tempo fader) and make it permanent.
So for example, the song is 120 BPM. He wants to always have the song play at e.g. 125 BPM.
geposted Thu 02 Jul 20 @ 6:54 am
THIS :)
I want the pitch fader to be persistent
geposted Fri 03 Jul 20 @ 8:59 pm
