Newest Update creates muffled sound on Deck 2 with Denion MC7000 controller. Get it together VDJ. If you are gonna update, its supposed to improve and fix existing issues. Not cause a new one every update.
Get this fixed. I have a wedding tomorrow
geposted Thu 02 Jul 20 @ 1:59 pm
You get muffled sound with
- equalizer at 50%
- ColorFX/Filter at 50%
- no Effect applied
? and only on right deck ??
There must be something wrong with the above.
One other case is to have some Mix FX applying to your crossfader.
Assign a custom button as effect_mixfx_activate and see if it's enabled
- equalizer at 50%
- no Effect applied
geposted Thu 02 Jul 20 @ 2:06 pm
Yes
geposted Thu 02 Jul 20 @ 2:08 pm
I have an MC6000 MK2 did the same thing on all decks. Updated this morning cause it said there was one and now my main board of my MC7000 Right deck 2 doesn't work
geposted Thu 02 Jul 20 @ 2:09 pm
Deck 4 on right works but not deck 2. No effects are on, nothing. My MC6000 MK2 did the same thing its not me. This is a bug in these 2021 updates thats continually not getting fixed. If you want to touch base with me to somehow hear this I will gladly call or what not
geposted Thu 02 Jul 20 @ 2:10 pm
I could further troubleshoot but since you seem to be in a hurry, do this..
With VirtualDJ closed, goto Documents/VirtualDJ folder, rename the settings.xml file to old-settings.xml
Start VirtualDJ and see if everything is working as it should.
geposted Thu 02 Jul 20 @ 2:12 pm
Worked thanks. All good
geposted Thu 02 Jul 20 @ 2:20 pm
