VDJ shuts down when opening settings.
Clean-ish install. The first time ever being installed on this computer, but it did do an update from VDJ8.? to VDJ2020
I have tried:
Finding similar issues in the forum.
Disabling the firewall
Disabling Virus Protection
Renaming the Settings.XML in the Documents folder
Renaming the Database.XML in the Documents folder
Computer: Dell Vostra
OS: Windows 10 PRO -64 bit
VDJ: 8.4-64 b5874
I could use some guidance on what to try next.
I have tried:
VDJ: 8.4-64 b5874
geposted Sat 04 Jul 20 @ 3:13 pm
I installed Version B5980. Still the same issue. I am reasonably sure the issue is my computer. I just need some guidance from anyone willing to help.
geposted Mon 06 Jul 20 @ 11:59 pm
