I guys i would like some help on this my jog wheel display is running with a glitch using the stems version.the sound and everything else is ok.help please
geposted Tue 07 Jul 20 @ 3:55 pm
What's the glitch?
geposted Tue 07 Jul 20 @ 4:09 pm
The display in the jog wheel is hesitant.the music plays ok.
geposted Wed 08 Jul 20 @ 4:42 am
I just tried with my SX2 and it seems OK.
Windows 10 64 bit, with VDJ 2021 b5980.
Can you give more info?
geposted Wed 08 Jul 20 @ 10:57 am
so the white display in yours is normal?mines runs and pause for a sec then go bit it doesn't affect the music windows 1o 64 bit version 2021
geposted Wed 08 Jul 20 @ 6:33 pm
geposted Wed 08 Jul 20 @ 6:34 pm
Yes it's normal
Yes it's normal
Yes it's normal
Yes it's normal
Yes it's normal
geposted Wed 08 Jul 20 @ 6:35 pm
so the white bars that goes around in your jogwheel display is normal?mines runs and pause for a sec then go bit it doesn't affect the music windows 1o 64 bit version 2021.
geposted Wed 08 Jul 20 @ 6:36 pm
sorry for the typo 😅
geposted Wed 08 Jul 20 @ 6:37 pm
my sx2 firmware and drivers are up to date windows pc win 10 64 bit 8 gig rams 1t hard drive.am at a lost.only option I have is to go back to 2020.
geposted Wed 08 Jul 20 @ 6:42 pm
When does it pause? I only loaded tracks and played them. I didn't check to see what happened when the mathengine analyses a track.
If you see the display slow down during the mathengine stem analysis then it's probably due to the high CPU load.
geposted Wed 08 Jul 20 @ 6:45 pm
im running into the same issue, ( amongst others with this new version)
I also have v8.4 (2020) and this is not an issue). Its not a CPU or GPU taxation issue, it just stops 4 times per second.
Surface book 2 15 inch
Eighth-gen Intel Quad-Core i7-8650U, 4.2GHz "max turbo"
16GB RAM.
512GB
Nvidia GeForce GTX 1060, 6GB graphic memory.
16GB RAM.
512GB
geposted Sat 25 Jul 20 @ 9:03 pm
Same issue on my sx2 :
when I leave the "stems pad" activated instead of the "hotcue" page, the white ring in the middle of decks lag. It seems that it is the blinking effect of the pads which is problematic. If I switch to another pad page (slicer or sampler,...), no more worries about controller ring lag.
geposted Mon 10 Aug 20 @ 8:54 am
That's strange. I just tried my SX2 again here, and see no such delay with the white ring in the jog display.
FYI this is on a 4.2GHz i7 CPU with 16GB RAM, using CPU for stems.
geposted Mon 10 Aug 20 @ 9:19 am
Issue is already fixed in latest Early Access Build
geposted Mon 10 Aug 20 @ 9:37 am
Ah, that explains it. :-)
geposted Mon 10 Aug 20 @ 10:27 am
ok, thanks. I m not in early acces, i will wait.
geposted Mon 10 Aug 20 @ 3:42 pm
