So I have the pro version and the VSM 5. The problem I have is that I use 4 deck mode. I can use the individual channels to control the volume on each deck. However deck 1 volume whether it is the channel or when I select it on the crossfader. Controls the volume on all decks regardless. It started doing that shortly after the VDJ 8 updated. I do not know how to change that back. I have been using VDJ since before VDJ 8 on pro and for some reason. It was only after VDJ 8 updated one of the times. I also have had VSM 2 and VSM4 prior to the 5. Do you know how to fix this issue?
geposted Tue 07 Jul 20 @ 11:47 pm
When you plug the VMS5 in, VDJ should pop up a window saying that you've connected the VMS5. It asks if you want to use the soundcard. Click the button.
In the audio config area, there's a big button with a picture of the VMS5 on it. Click the button.
There's also a VDJ setup guide for the VMS5 here (download/hardware manuals) which shows all the possible audio settings.
geposted Wed 08 Jul 20 @ 7:58 am
