I have an Akai APC Mini controller, which I have been using with Soundswitch to control my lighting. As I don't use all the pads or sliders, I was hoping to programme some for use with VDJ. However, if I start Soundswitch first, the controller works for SS but VDJ cannot connect to the controller. If I start VDJ first, SS sees it but none of the programmed pads or sliders work as they should in SS - it's like all the settings have been over-ridden by VDJ. Is it and should it be possible to use the same controller for both softwares, and if so, can anyone help?
geposted Wed 08 Jul 20 @ 12:12 pm
Applications want to have full and exclusive access to a MIDI device. Therefore you cant have both SS and VDJ controlling the same MIDI device.
If you like SS and wish to have one single MIDI device to control both, then ask SS to fully implement OS2L and offer os2l_buttons (like ShowXpress, SweetLight, TheLightingController have), and then you can use your MIDI with VDJ and assign a few buttons with os2l_ buttons to control SS through OS2L.
geposted Wed 08 Jul 20 @ 2:59 pm
VDJ blindly takes all access to all MIDI devices (even those not existing raising multiple errors in chain everytime a new device is connected to computer)
But no need of MIDI in SS anymore, use OS2l (supported by both)
http://fr.virtualdj.com/forums/230591/VirtualDJ_Plugins/SoundSwitch_now_supports_OS2L.html :)
One way (as you notice) being to use Akai APC Mini controller with VDJ and map/remap your controller free pads to send some os2l commands
geposted Wed 08 Jul 20 @ 4:16 pm
Nicotux wrote :
...use OS2l (supported by both) ...... to send some os2l commands
Unfortunately this wont work, SS is only using OS2L mostly to get Beat information and hasnt implemented the os2l_ buttons/commands
geposted Wed 08 Jul 20 @ 4:27 pm
Thanks for the clarification. I'll pester Soundswitch but at least I know it's not something I was doing wrong.
geposted Wed 08 Jul 20 @ 5:06 pm
