i have a computer with windows xp sp2 32 bit
and a pioneer ddj-sx
can someone send me the latest ver of vdj that can work with the sx mapping?
please help me i need it fast for today
tnx for you all
roy
tnx for you all
roy
geposted Thu 09 Jul 20 @ 2:18 am
geposted Thu 09 Jul 20 @ 2:22 am
4787 is the last build that works with XP not sure about SP2
geposted Thu 09 Jul 20 @ 7:10 am
I'd suggest you try to upgrade your OS. You may be able to get Windows 10 on there, but if not then Windows 8.1 may be possible.
geposted Thu 09 Jul 20 @ 8:30 am
