until the 8.5 update I was using the 32bit version just because 64bit didn't support SPOUT, but know but now I saw that there is a 64bit version of the plugin, so I upgraded and notice that the "ADDITIVE" it doesn't work the way it should and it is practically the only transition I use all the time.
When moving the video crossfader from left to right, only a "fade" occurs up to 50% and the video from deck B is already completely mixed. When moving the fader from right to left, nothing happens until it reaches 50%, which is when video B starts to fade out to video A.
Here is a video showing the difference between the two versions (32 and 64 bits) of the transition
I really hope that this is fixed because, as i said, it's pretty much the only transition that iuse
geposted Sat 11 Jul 20 @ 3:41 pm
