Topic: Denon DNX-1600 Mic setup
djmrmcPRO InfinityMember since 2009
Hi all,
I can't for the life of me figure out how to set the mic up within VDJ when I am using my Denon DN-X1600.
Everything else works perfectly as in audio settings but I wanted to use a mic on my live streams. Is it a limitation because I am using an external mixer?
Cheers.
geposted Sun 19 Jul 20 @ 3:49 am
geposted Sun 19 Jul 20 @ 8:47 am
groovindj wrote :
https://www.virtualdj.com/wiki/Record%20Microphone%20Input.html
Thanks goovindj but i went through that earlier today. I already have a loop back setup which works fine and I obviously get audio output.
I did as the wiki said but no audio from the Mic.
geposted Sun 19 Jul 20 @ 12:20 pm
Then you should be able to record the mic.
You need to explain exactly how you've connected everything, with what cables, where they go (ins and outs), where the mic is plugged in etc.
We can't see what you've done. You have to tell/show us.
geposted Sun 19 Jul 20 @ 12:26 pm
Mixer is connected via usb.
Mic is plugged into Mic input 1 on the mixer.
Speaking into the Mic is then visible on the master VU meters on the mixer.
geposted Sun 19 Jul 20 @ 1:02 pm
Well that's a start. What about the rest? What's your audio config in VDJ? What USB audio routing have you got configured from the util menu on the X1600?
geposted Sun 19 Jul 20 @ 1:43 pm
I have this sorted now. You pointed me in the right direction groovindj.
I had my out select as Chan 1/2 rec. I should have it set it to Chan 1/2 Master.
Thanks for the assistance.
Cheers.
geposted Tue 21 Jul 20 @ 12:11 am
Glad to help!
geposted Tue 21 Jul 20 @ 7:27 am
