Vdj 2021 Won't Recognize My DDj Sr, It Say It Won't Load Up ASIO Driver, HOw To Fix This Problem, Thought This Was Plug And Play If You Have Previous License For Controller ?
geposted Mon 20 Jul 20 @ 6:35 am
Just realized that I haven't used my SR2, since the upgrade. So, connected the SR2, and it worked like a charm. Do you have the latest drivers, can you post a screenshot of your audio configuration?
geposted Mon 20 Jul 20 @ 7:05 am
My DDJ-SR works fine with VDJ2021
You can see me plug it in and use it a little bit (to show the locked hot cues pad page on this controller, because of it's pads plus functionality) in this video:
geposted Mon 20 Jul 20 @ 1:09 pm
Check that you don't have the SR selected as default audio interface in Windows.
geposted Mon 20 Jul 20 @ 1:25 pm
