How do I connect my audio technica lp120x to my ddj-800 using Virtual DJ? I’ve tried several methods and my turntables still won’t connect to Virtual DJ. I have Virtual DJ timecode vinyls but I yield zero results. Help please!
geposted Mon 20 Jul 20 @ 8:45 pm
What were those "several methods"?
geposted Mon 20 Jul 20 @ 8:55 pm
Make sure you have the correct audio setup :
https://www.virtualdj.com/manuals/hardware/pioneer/ddj800/installation.html
Change the line-in entries to timecode input.
See here: https://www.virtualdj.com/manuals/virtualdj/settings/audiosetup/timecode.html
geposted Mon 20 Jul 20 @ 9:22 pm
@groovindj I’ve tried switching all the channels, I’ve tried following several YouTube VDJ DVS setup videos, I’ve tried playing with the internal VDJ settings and nothing.
geposted Mon 20 Jul 20 @ 9:56 pm
@Rune.. thanks bro. I’ll check it out and see if I have any luck.
geposted Mon 20 Jul 20 @ 9:58 pm
Keep in mind that you might have to upgrade your license too. I think with your current Home one listed under your name, you either can't do it or you'll only get to play for 10 minutes.
https://www.virtualdj.com/products/virtualdj/price.html#comparison
geposted Tue 21 Jul 20 @ 12:13 pm
@visionz5 yeah I bought the pro licenses a while back when I was doing gigs on the side while overseas working.
geposted Tue 21 Jul 20 @ 12:15 pm
You subscribed maybe. You didn't buy it because you don't have three stars and the words Pro Infinity under your user name.
geposted Tue 21 Jul 20 @ 12:17 pm
Could be that you used a different email back then?
If so, add the email of purchase to your account, if you have a license.
That way it will all show up and work, as far as license go at least ;-)
https://www.virtualdj.com/users/link.html
geposted Tue 21 Jul 20 @ 12:34 pm
