Topic: Onsongload request
Currently the above feature works for newly loaded songs...not for the clone action..so the variables loaded in the script are not executed if the same song is cloned over...it could be added as an option...for now I have mapped what I would have placed in the onsongload script in my clone shortcut..which works well..but IMO onsongload should respect clone action
geposted Fri 24 Jul 20 @ 1:06 am
NicotuxHome userMember since 2014
Yes, usefull to make remember this issue
Clone action is no more a load action....
So that:
- ONSONGLOAD is not executed
- extra specified deck is not created and song goes to default instead
geposted Fri 24 Jul 20 @ 1:48 am
Well there should be an option at least to have clone respect the onsongload...
geposted Fri 24 Jul 20 @ 2:19 am
If the song was not loaded yet in the other deck ONSONGLOAD will also be executed.
geposted Fri 24 Jul 20 @ 7:05 am
Well for instance when beat juggling or playing with a track...sometimes both decks are loaded with the same song...so for instance I load deck a..clone to b...mess with it on deck b..then I want to clone back to A.. To match the song position etc...in this instance onsongload will not work
geposted Fri 24 Jul 20 @ 10:34 am
