Running VDJ 2021 on Windows 10. Videos play in VLC correctly but in VDJ2021, several videos studder/freeze frame on output. Audio continues through HDMI without a glitch. Repeating video again and doesn't always glitch 2nd time played. Very random. Win10Pro, 48GB RAM, i7-9700, NVIDIA GeForce RTX 2060. Never had this issue with VDJ2020. Any ideas? Items to check in settings? Hate to have to roll back.
geposted Sat 25 Jul 20 @ 4:06 am
The difference between VDJ 2020 and VDJ 2021 is the stems technology, which uses the mathengine on the NVIDIA chip.
When you get these glitches, is the mathengine on? Have you tried with it turned off?
geposted Sat 25 Jul 20 @ 8:26 am
You can also try the useLowPowerGPU setting to change which gpu VirtualDJ uses for interface and video output.
geposted Sat 25 Jul 20 @ 8:30 am
Thank you for the advice! I disabled the mathEngine and it appears to resolve the issue (will test over the next few days). Disadvantages of that disabled?
geposted Sat 25 Jul 20 @ 2:30 pm
Disadvantage would be inability to use stems functionality.
geposted Sat 25 Jul 20 @ 2:49 pm
Did you try Adions suggestion?? With the mathEngine still on?
geposted Sat 25 Jul 20 @ 3:05 pm
