Hello. On my 32 bit machine using version 8, I had the backspin working fine which I renamed to backspin1.dll from VDJ 7.
However on my 64 bit machine it says backspin incompatible. Is there another work around for this please. The same applies to brake.
geposted Sun 26 Jul 20 @ 8:07 pm
Can use the native built-in backspin effect
geposted Sun 26 Jul 20 @ 8:11 pm
Donwnload them from extensions/effects in the VDJ config window.
geposted Sun 26 Jul 20 @ 8:12 pm
Is it the same one as in VDJ7
geposted Sun 26 Jul 20 @ 8:20 pm
Already had it but its not the same. The original one
geposted Sun 26 Jul 20 @ 8:22 pm
The one you refer to is very old, and 32-bit.
So that one can not be used with 64-bit program
Click the [+] button next to the effect drop down, and you can adjust its length to sound like you want to
geposted Sun 26 Jul 20 @ 8:34 pm
Thanks alot for your help but this backspin is not for me. The old one worked great because I could immediately press a hot cut while spinning to go back to the the beginning but I'll have to move on now.
Thanks again
Thanks again
geposted Sun 26 Jul 20 @ 8:38 pm
