Hello,
I'm looking to get a Traktor contoller, probably an S3. I'd like to try the Traktor software as well as renewing my VDJ (or transferring if that's possible?), Is there a way of transferring my virtual folders and playlists from VDJ to Traktor?
Thanks for any help or pointers, apologies if this has been requested before but I can't seem to find the right thread.
geposted Mon 27 Jul 20 @ 9:32 pm
user21900669 wrote :
Hello,
FYI, S3 is natively supported in the latest Build, so good to go.
Other supported hardware from NI : https://www.virtualdj.com/products/hardware.html?brand=ni
..renewing my VDJ (or transferring if that's possible?),
You will have to purchase a new Home Plus license for the S3. The one you have for Partymix, will not unlock the S3. Consider buying the Pro Infinity or Pro subscription or else you will find yourself in the same position when you get a new hardware.
No, there is not.
geposted Mon 27 Jul 20 @ 9:59 pm
geposted Mon 27 Jul 20 @ 11:03 pm
Perfect, thanks for all the info and license tip.
geposted Tue 28 Jul 20 @ 7:08 pm
