Forum: VirtualDJ Skins
Topic: Seeking... Simple iPad Skin for 8 Decks
Hi I'm looking to see if a skin exists or could be created for an iPad that supports: Pause/Play, Level Controls, PFL Buttons and Track Names for 8 Decks. Is this possible?
Thanks!
-Lou
geposted Mon 27 Jul 20 @ 9:39 pm
anything is possible.. ;-)
But why 8 decks? seems a bit "over the top" perhaps....
geposted Mon 27 Jul 20 @ 10:49 pm
There is already an 8 deck skin on VDJ 2021.
Its name is "VirtualProducer 8 Deck".
geposted Mon 27 Jul 20 @ 11:01 pm
Not for the remote app there isn't
geposted Mon 27 Jul 20 @ 11:03 pm
NicotuxHome userMember since 2014
As i use many decks with many video windows something like that lay in my drawer...
8 decks voicemeeter with looking (2d sliders are ready even not used yet)
https://imgur.com/eSFYqFp
badly not ready for remote :\ (of course uses placeholders)
geposted Mon 27 Jul 20 @ 11:35 pm
geposted Tue 28 Jul 20 @ 1:12 pm
geposted Tue 28 Jul 20 @ 1:35 pm
@Nicotux- The trouble is most of what your scripting probably won’t work on a remote skin. (I assume as your likely using the main skin engine).
If the OP gives more information about use case etc. I might be persuaded to knock something together.
geposted Tue 28 Jul 20 @ 2:44 pm
As I said, ... not for remote :( as long as there is no placeholders support in remote skin engine, script would be insane ^^
Usefull with a touchscreen and a 8 decks skin (i.e. using ipad/tablet as a desktop extention) or stand alone if adding a browser
Scripting, it is a good exercise (empty background image no pic, uncommon style...)
Added Artist & title (green when playing, gray loaded, nothing when empty), uses fader_start & fader_stop
https://imgur.com/LgeUdZ1
geposted Tue 28 Jul 20 @ 3:18 pm
