I would like to change the x2 button on my hotpads so when i press shift and that button my stems are activated on the pads. Any idea what i need to add to achieve this? :)
geposted Tue 28 Jul 20 @ 4:02 pm
x2 button? you're going to have give more controller info as I'm only good at guessing on mondays
geposted Tue 28 Jul 20 @ 4:52 pm
Its the bottom right pad #8 on a Mixtrack Pro s4/c4 1/2x - 2x
https://www.digitaldjtips.com/reviews/numark-mixtrack-pro-ii/
geposted Tue 28 Jul 20 @ 8:06 pm
well a quick look and the mapping for that device is horrible, not really a atomix fault as they've got to make a device work to makers spec/ as user expects, I know where to begin but it would be totally remapping all the pads to actually be 8 pads.
geposted Tue 28 Jul 20 @ 10:16 pm
So because of the shift functionality it messes things up right? I am looking at a Prime 4 or a DDJ1000 soon this is just an old controller from the bottom of a cupboard; I have already had to remap so i have a gain for each channel :)
I would be really cool (to me) to be able too map 4 hot cues and the stems bar Vocals on the Pads or alternatively have a way to shift to the stems from hotcues on a higher end controller.
A one click way to re-enable all stems is something that has to be already available right?
geposted Wed 29 Jul 20 @ 5:46 am
I did a video on this... https://www.youtube.com/watch?v=i8Y7Es-aHZ4
geposted Thu 30 Jul 20 @ 2:10 am
Thanks a lot!
geposted Thu 30 Jul 20 @ 6:16 am
