Topic: I´m i missning the bleed parameter?
PuttePRO InfinityMember since 2004
Hi in BUILD 6042 (2020-07-27) i read "new parameter (in pads section) called "bleed"
But i cant find it in my VDJ, is it there some parameter i options that must be set so it show?
Im running the latest version
geposted Tue 28 Jul 20 @ 10:21 pm
Maybe the description of the stems_bleed action (used in the Stems Pads page) helps ..
If you still don't get what i get, then perhaps you have edited the default Stems page, so you will have to delete the Stems.xml file from Documents/VirtualDJ/Pads folder.
edit or just use "reset page" inside the pad editor, same result.
geposted Tue 28 Jul 20 @ 10:44 pm
Thanks, deleated the stems.xml and now the parameter is in place..
geposted Tue 28 Jul 20 @ 11:02 pm
