Hello to the community.
i just finish a small cool mapping for the Denon MC4000, i included too some modifications.
Here the list:
-Modification of the Play/Pause button, now is blinking when 30sec remain on the track (1000ms and 500ms the last 15sec).
-Adjust the blinking of the CUE and Play/Pause button to 1300ms.
-Stems pads section take place now in the loop roll pads section ( i almost never use the loop roll section and she's already exist in the effect section).
-Blinking symmetric colors (blue and cyan) for the stems pads and constant color (red) if you active one stem pad.
-The Kick stem is activate/desactivate by SHIFT + PAD1.
-HOTCUE from 1 to 4 are red now (PadMode button is red for this Hotcue section)
-Complete Stems pads with name, location and colors integration in pads panel.
-master volume is setting to 45% when you open VDJ.
-Blinking function for Key Lock (850ms).
-Blinking function for SYNC button (3500ms).
Ok i give you the XML for the pad section, you just to have to open a existing XML in C:\Users\Name\Documents\VirtualDJ\Pads select all, paste and save the XML with the name stems.
<?xml version="1.0" encoding="UTF-8"?>
<page name="stems">
<pad1 name="Vocal" color="color 'blue'">stem_pad 'vocal'</pad1>
<pad2 name="Instru" color="color 'orange'">stem_pad 'instru'</pad2>
<pad3 name="Bass" color="color 'violet'">stem_pad 'bass'</pad3>
<pad5 name="Kick" color="color 'red'">stem_pad 'kick'</pad5>
<pad6 />
<shift_pad1 />
<shift_pad2 />
<shift_pad3 />
<shift_pad5 name="Kick" color="color 'red'">stem_pad isolate 'kick'</shift_pad5>
<shift_pad6 />
<param1 name="`stems_bleed`">stems_bleed</param1>
<pad4 color="color 'yellow'" name="Hit Hat">stem_pad 'hihat'</pad4>
<shift_pad7 />
<shift_pad4 />
</page>
To finish here the complete mapping, same manipulation like above and save with this path: C:\Users\Name\Documents\VirtualDJ\Mappers and this name : Denon DJ MC4000 - Mapping with stems.
<mapper device="MC4000" author="Atomix Productions" version="850" date="2020-07-29">
<info>http://www.virtualdj.com/manuals/hardware/denon/mc4000/index.html</info>
<map value="SHIFT" action="shift" />
<map value="JOG_TOUCH" action="shift ? touchwheel_touch 'search' : touchwheel_touch" />
<map value="JOG" action="shift ? touchwheel 'search' : touchwheel" />
<map value="PITCH" action="pitch" />
<map value="VINYL" action="vinyl_mode" />
<map value="SHIFT_VINYL" action="dump while_pressed" />
<map value="LED_VINYL" action="dump ? blink : vinyl_mode" />
<map value="kEYLOCK" action="key_lock" />
<map value="LED_kEYLOCK" action="key_lock ? blink 850ms ?" />
<map value="SHIFT_kEYLOCK" action="pitch_range +1" />
<map value="PITCHBEND-" action="pitch_bend -2% 500ms" />
<map value="PITCHBEND+" action="pitch_bend +2% 500ms" />
<map value="SHIFT_PITCHBEND-" action="seek -8" />
<map value="SHIFT_PITCHBEND+" action="seek +8" />
<map value="SYNC" action="sync" />
<map value="SHIFT_SYNC" action="masterdeck" />
<map value="LED_SYNC" action="blink 3500ms ? shift ? masterdeck : is_sync :" />
<map value="CUE" action="cue_stop" />
<map value="SHIFT_CUE" action="goto_start" />
<map value="LED_CUE" action="loaded ? pause ? cue ? on : blink 1300ms : off : off" />
<map value="PLAY" action="play_pause" />
<map value="SHIFT_PLAY" action="play_stutter" />
<map value="LED_PLAY" action="pause ? play ? on : blink 1300ms : songpos_remain 15000ms ? blink 500ms : songpos_remain 30000ms ? blink 1000ms : on : off" />
<map value="LOOP_AUTO" action="loop" />
<map value="LOOP_HALF" action="loop_half" />
<map value="SHIFT_LOOP_HALF" action="loop ? wheel_mode 'loop_in,jog' +1 : loop_in" />
<map value="LOOP_DOUBLE" action="loop_double" />
<map value="RELOOP" action="reloop" />
<map value="SHIFT_LOOP_AUTO" action="loop ? loop off : loop 4" />
<map value="SHIFT_LOOP_DOUBLE" action="loop ? wheel_mode 'loop_out,jog' +1 : loop_out" />
<map value="SHIFT_RELOOP" action="loop_roll_mode" />
<map value="LED_LOOP_AUTO" action="loop ? blink 750ms : on" />
<map value="LED_LOOP_HALF" action="shift ? wheel_mode 'loop_in' ? blink : loop_in : on" />
<map value="LED_LOOP_DOUBLE" action="shift ? wheel_mode 'loop_out' ? blink : loop : on" />
<map value="LED_RELOOP" action="shift ? loop_roll_mode : reloop_exit" />
<map value="SAMPLER_BANK1" action="sampler_bank -1 & down ? set '$sam1down' 1 : set '$sam1down' 0" />
<map value="SAMPLER_BANK2" action="sampler_mode -1 & down ? set '$sam2down' 1 : set '$sam2down' 0" />
<map value="SAMPLER_BANK3" action="sampler_bank +1 & down ? set '$sam3down' 1 : set '$sam3down' 0" />
<map value="SAMPLER_BANK4" action="sampler_mode +1 & down ? set '$sam4down' 1 : set '$sam4down' 0" />
<map value="SAMPLER_BUT1" action="var '$MCmodebutton' ? sampler_bank -1 : sampler_pad 1" />
<map value="SAMPLER_BUT2" action="var '$MCmodebutton' ? sampler_mode -1 : sampler_pad 2" />
<map value="SAMPLER_BUT3" action="var '$MCmodebutton' ? sampler_bank +1 : sampler_pad 3" />
<map value="SAMPLER_BUT4" action="var '$MCmodebutton' ? sampler_mode +1 : sampler_pad 4" />
<map value="SHIFT_SAMPLER_BUT1" action="sampler_stop 1" />
<map value="SHIFT_SAMPLER_BUT2" action="sampler_stop 2" />
<map value="SHIFT_SAMPLER_BUT3" action="sampler_stop 3" />
<map value="SHIFT_SAMPLER_BUT4" action="sampler_stop 4" />
<map value="LED_SAMPLER_BUT1" action="var '$MCmodebutton' ? var '$sam1down' : sampler_loaded 1 ? sampler_pad 1 ? blink 400ms : on : off" />
<map value="LED_SAMPLER_BUT2" action="var '$MCmodebutton' ? var '$sam2down' : sampler_loaded 2 ? sampler_pad 2 ? blink 400ms : on : off" />
<map value="LED_SAMPLER_BUT3" action="var '$MCmodebutton' ? var '$sam3down' : sampler_loaded 3 ? sampler_pad 3 ? blink 400ms : on : off" />
<map value="LED_SAMPLER_BUT4" action="var '$MCmodebutton' ? var '$sam4down' : sampler_loaded 4 ? sampler_pad 4 ? blink 400ms : on : off" />
<map value="SAMPLER_VOLUME" action="sampler_volume_master" />
<map value="FX1_ON" action="effect_active" />
<map value="FX2_ON" action="effect_3slots_layout ? effect_active 2 : effect_select -1" />
<map value="FX3_ON" action="effect_3slots_layout ? effect_active 3 : effect_select +1" />
<map value="LED_FX1_ON" action="shift ? effect_3slots_layout ? effect_active : effect_show_gui : effect_active" />
<map value="LED_FX2_ON" action="shift ? effect_3slots_layout ? effect_active 2 : effect_button 1 : effect_3slots_layout ? effect_active 2 : off" />
<map value="LED_FX3_ON" action="shift ? effect_3slots_layout ? effect_active 3 : effect_button 2 : effect_3slots_layout ? effect_active 3 : off" />
<map value="SHIFT_FX1_ON" action="effect_3slots_layout ? effect_select 1 +1 : effect_show_gui" />
<map value="SHIFT_FX2_ON" action="effect_3slots_layout ? effect_select 2 +1 : effect_button 1" />
<map value="SHIFT_FX3_ON" action="effect_3slots_layout ? effect_select 3 +1 : effect_button 2" />
<map value="FX1" action="effect_slider 1" />
<map value="FX2" action="effect_3slots_layout ? effect_slider 2 1 : effect_slider 2" />
<map value="FX3" action="effect_3slots_layout ? effect_slider 3 1 : effect_slider 3" />
<map value="SHIFT_FX1" action="effect_3slots_layout ? effect_slider 1 2 : effect_slider 4" />
<map value="SHIFT_FX2" action="effect_3slots_layout ? effect_slider 2 2 : effect_slider 5" />
<map value="SHIFT_FX3" action="effect_3slots_layout ? effect_slider 3 2 : effect_slider 6" />
<map value="TAP" action="beat_tap" />
<map value="SHIFT_TAP" action="effect_3slots_layout" />
<map value="LED_TAP" action="effect_3slots_layout" />
<map value="FX_BEATS" action="shift ? device_side 'left' ? video_transition_slider 1 : deck master video_fx_slider 1 : device_side 'left' ? video_transition_select : deck master video_fx_select" />
<map value="FX_BEATS_PUSH" action="shift ? device_side 'left' ? effect_show_gui 'transition' : deck master effect_show_gui 'video' : device_side 'left' ? video_transition : deck master video_fx" />
<map value="GAIN" action="gain" />
<map value="EQ_HIGH" action="eq_high" />
<map value="EQ_MID" action="eq_mid" />
<map value="EQ_LOW" action="eq_low" />
<map value="FILTER" action="filter" />
<map value="PFL" action="pfl" />
<map value="VOLUME" action="volume" />
<map value="VU_METER" action="get level" />
<map value="CROSSFADER" action="crossfader" />
<map value="BROWSE" action="browser_scroll" />
<map value="SHIFT_BROWSE" action="param_bigger 0 ? browser_scroll +10 : browser_scroll -10" />
<map value="LOAD" action="shift ? clone_from_deck : holding ? unload : load" />
<map value="BACK" action="browser_folder" />
<map value="SHIFT_BACK" action="skin_panelgroup 'mixer' +1" />
<map value="BROWSE_PUSH" action="shift ? browser_zoom : browser_window 'songs'" />
<map value="LOAD_PREPARE" action="playlist_add" />
<map value="SHIFT_LOAD_PREPARE" action="holding ? show_splitpanel 'sideview' : show_splitpanel 'sideview' ? browser_window 'sideview' ? sideview +1 : browser_window 'sideview' : show_splitpanel 'sideview' & browser_window 'sideview'" />
<map value="HEADPHONES_VOLUME" action="headphone_volume" />
<map value="HEADPHONES_MIX" action="headphone_mix" />
<map value="HEADPHONES_SPLIT" action="down ? setting 'SplitHeadphones' on : setting 'SplitHeadphones' off" />
<map value="PADSMODE" action="set 'MCmodebutton' 1 while_pressed & set '$MCmodebutton' 1 while_pressed" />
<map value="PAD1" action="var 'MCmodebutton' ? set 'MCmode' 0 & pad_page 'hotcues' : var 'MCmode' 3 ? stem_pad 'vocal' : var 'MCmode' 2 ? cue_loop 1 : var 'MCmode' 1 ? hot_cue 5 : hot_cue 1" />
<map value="PAD2" action="var 'MCmodebutton' ? set 'MCmode' 1 & pad_page 'hotcues' : var 'MCmode' 3 ? stem_pad 'instru' : var 'MCmode' 2 ? cue_loop 2 : var 'MCmode' 1 ? hot_cue 6 : hot_cue 2" />
<map value="PAD3" action="var 'MCmodebutton' ? set 'MCmode' 2 & pad_page 'cueloop' : var 'MCmode' 3 ? stem_pad 'bass' : var 'MCmode' 2 ? cue_loop 3 : var 'MCmode' 1 ? hot_cue 7 : hot_cue 3" />
<map value="PAD4" action="var 'MCmodebutton' ? set 'MCmode' 3 & pad_page 'stems' : var 'MCmode' 3 ? stem_pad 'hihat' : var 'MCmode' 2 ? cue_loop 4 : var 'MCmode' 1 ? hot_cue 8 : hot_cue 4" />
<map value="LED_PADSMODE" action="var 'MCmode' 3 ? constant 0.9 : var 'MCmode' 2 ? constant 0.5 : var 'MCmode' 1 ? constant 0.3 : constant 0.5" />
<map value="LED_PAD1" action="var 'MCmodebutton' ? var 'MCmode' 0 ? constant 0.5 : constant 0.1 : var 'MCmode' 3 ? stem_pad 'vocal' ? blink 1500ms ? constant 0.2 : constant 0.9 : constant 0.5 : var 'MCmode' 2 ? cue_loop 1 ? constant 0.5 : constant 0.1 : var 'MCmode' 1 ? hot_cue 5 ? constant 0.2 : constant 0.1 : hot_cue 1 ? constant 0.5 : constant 0.1" />
<map value="LED_PAD2" action="var 'MCmodebutton' ? var 'MCmode' 1 ? constant 0.2 : constant 0.1 : var 'MCmode' 3 ? stem_pad 'instru' ? blink 1500ms ? constant 0.9 : constant 0.2 : constant 0.5 : var 'MCmode' 2 ? cue_loop 2 ? constant 0.5 : constant 0.1 : var 'MCmode' 1 ? hot_cue 6 ? constant 0.2 : constant 0.1 : hot_cue 2 ? constant 0.5 : constant 0.1" />
<map value="LED_PAD3" action="var 'MCmodebutton' ? var 'MCmode' 2 ? constant 0.5 : constant 0.1 : var 'MCmode' 3 ? stem_pad 'bass' ? blink 1500ms ? constant 0.9 : constant 0.2 : constant 0.5 : var 'MCmode' 2 ? cue_loop 3 ? constant 0.5 : constant 0.1 : var 'MCmode' 1 ? hot_cue 7 ? constant 0.2 : constant 0.1 : hot_cue 3 ? constant 0.5 : constant 0.1" />
<map value="LED_PAD4" action="var 'MCmodebutton' ? var 'MCmode' 3 ? constant 0.9 : constant 0.1 : var 'MCmode' 3 ? stem_pad 'hihat' ? blink 1500ms ? constant 0.2 : constant 0.9 : constant 0.5 : var 'MCmode' 2 ? cue_loop 4 ? constant 0.5 : constant 0.1 : var 'MCmode' 1 ? hot_cue 8 ? constant 0.2 : constant 0.1 : hot_cue 4 ? constant 0.5 : constant 0.1" />
<map value="SHIFT_PAD1" action="var 'MCmode' 3 ? stem_pad 'kick' : var 'MCmode' 2 ? cue_loop 1 'jump' : var 'MCmode' 1 ? delete_cue 5 : delete_cue 1" />
<map value="SHIFT_PAD2" action="var 'MCmode' 3 ? loop_roll 0.25 : var 'MCmode' 2 ? cue_loop 2 'jump' : var 'MCmode' 1 ? delete_cue 6 : delete_cue 2" />
<map value="SHIFT_PAD3" action="var 'MCmode' 3 ? loop_roll 0.5 : var 'MCmode' 2 ? cue_loop 3 'jump' : var 'MCmode' 1 ? delete_cue 7 : delete_cue 3" />
<map value="SHIFT_PAD4" action="var 'MCmode' 3 ? loop_roll 1 : var 'MCmode' 2 ? cue_loop 4 'jump' : var 'MCmode' 1 ? delete_cue 8 : delete_cue 4" />
<map value="ONINIT" action="master_volume 45%" />
</mapper>
Here the list:
<page name="stems">
<pad6 />
<shift_pad1 />
<shift_pad2 />
<shift_pad3 />
<shift_pad6 />
<shift_pad7 />
<shift_pad4 />
</page>
</mapper>
geposted Thu 30 Jul 20 @ 3:45 am
This is amazing DjAku-Aku, thank you so much.
I'm going to try it, not sure if I will be able to do that myself so I'm terrible messing with all this stuff.
geposted Thu 30 Jul 20 @ 9:11 am
As expected it doesn't work for me, pretty sure I'm doing something wrong.
I have your xml files ready as stated in their respectice directories ("stems" in Pads and "Denon DJ MC4000 - Mapping with stems" in Mappers). In VDJ I have selected the new mapping but the loops roll are working as always, not as stems pads.
geposted Thu 30 Jul 20 @ 11:47 am
hello my friend.
when you save the xml, did you add the .xml to the file? like this : Denon DJ MC4000 - Mapping with stems.xml for the mapping and stems.xml for the pad.
normally when you select the Denon DJ MC4000 - Mapping with stems the pad is organise like this in pad section (see the screenshot)
geposted Thu 30 Jul 20 @ 4:09 pm
He seems to have taken your information literally.
geposted Thu 30 Jul 20 @ 4:12 pm
it seems, i do the same operation like i describe and i have no problems,
geposted Thu 30 Jul 20 @ 4:19 pm
Edit
DjAku-Aku wrote :
hello my friend.
hello my friend.
Hi mate! Yes, I have the xml files with the code you writed and the .xml extension:
In MAPPERS: Denon DJ MC4000 - Mapping with stems.xml
In PADS: stems.xml
I still don't know where could be the error, maybe I'm lost in translation :-)
geposted Thu 30 Jul 20 @ 7:14 pm
In PADS: stems.xml
DjAku-Aku wrote :
hello my friend.
hello my friend.
In PADS: stems.xml
Hi hermano!
I apply the mapping and the stems xml like if i never use it before, mean i do the same operation like you.
In my case i move the 2 xml to my desktop and do a copy on a pendrive and rebbot the computer.
Ok the original mapping is by default etc...
i move the xml on their directories, restart the computer launch vdj, it's working.
i do the same manipulation on my backup computer and it's working.
I really don't know where your problem come from, i'm stuck to help you hermano...Sorry :(
PS: I think this thread is in the Wrong section, if an administrator can move it to general discussion please, regards aku-aku.
geposted Fri 31 Jul 20 @ 1:00 am
Hello community!
Actually i try to resolve in private the problem with SerieB with the pads mapping, but nothing work for this moment.
On my side i verified again and again the scripts, applied the same .xml on my backup computer and on the radio computer with a fresh install of vdj 2021, everything work fine for me.
I just need to know if someone have the MC4000 to make a test if the .xml work fine on your side, maybe it's going to help me to resolve the problem with SerieB.
Best regards, Aku-aku :)
geposted Sun 02 Aug 20 @ 5:55 pm
DjAku-Aku wrote :
Hello community!
Thank you so much Aku-aku, you have been very kind helping me through email. Sadly it still doesn't work for me, but pretty sure with the feedback of other MC-4000 users we will find the issue. ;-)
geposted Sun 02 Aug 20 @ 7:10 pm
Hi again DjAku-Aku and pals.
I have been trying to make it work your custom mapping again, it's so good to live without it but again I haven't any success.
Your custom STEMS mapping is as default, both xml files are applied correctly (in fact I have your Blinking function working), but as two years ago I can't make it work the pads with the stems, all the pads are working as loops.
Is there anything I have to change in the software? (pad menus/pad buttons selection doesn't make any difference). Would I need to remove the LOOP function at the right side? ( I never use it)
or maybe any change in the proper hardware?
Thanks for your help
geposted Thu 13 Oct 22 @ 8:18 am
No one?
geposted Sun 16 Oct 22 @ 12:19 pm
