Since I've upgrade vdj to vdj2021 my Controller American Audio VSM5 is not able to use the cue buttons correctly. When using the cue buttons it turns up the music as if it's the volume buttons. I'm not able to cue songs at all. Please Help!
geposted Fri 31 Jul 20 @ 1:53 am
HI mate, did you try to reset the Mapping of your VSM5 by default?
i experienced that kind of trouble last month, i just select the default mapping and working fine.
geposted Fri 31 Jul 20 @ 2:01 am
