Topic: Virtual DJ 2021 with Native Intruments Z2 - Page: 2
No, I mean in external mode with VDJ...
Rather than setting the audio config to master & headphones, you set each deck to go directly out to a Z2 channel.
That way you're not using the Z2 as a controller for VDJ's mixer - you're using the Z2 as a mixer.
I can't find any documentation or info on the Z2 audio options, but if there are individual channel groupings rather than just master & headphones, you could do it.
geposted Wed 05 Aug 20 @ 6:21 pm
Ahhh - thanks man. I'm not familiar with that option, but will definately look into it. :-)
Just one question, if I try this option, will the crossfader still work for video mixing?
geposted Thu 06 Aug 20 @ 5:56 am
Hi there ...
I’m using the same setup as you and I’m digging the VDJ ...I just have a problem off skipping only on the left deck did u experience the same issue?
geposted Thu 15 Oct 20 @ 12:58 am
