Hello.. Still learning the new script format
Trying to map a button on the keyboard to an effect which happens to be a native effect
I have:
I also tried just "Delay" ...neither seems to call up the effect, what I am not doing correctly?
Thanks!
I have:
effect "native_Delay" active while_pressed
Thanks!
geposted Sun 02 Aug 20 @ 2:01 am
effect_active ‘native_delay’ while_pressed
geposted Sun 02 Aug 20 @ 2:39 am
the correct verb: effect_active
https://www.virtualdj.com/wiki/VDJscript_verbs_v8_p2.html
correct sentence: effect_active "native_Delay" while_pressed
geposted Sun 02 Aug 20 @ 2:41 am
THANK YOU!!!
geposted Sun 02 Aug 20 @ 3:15 am
If you're mapping something, surely you'd be using the mapping config window? That window lists all the commands as you type the script.
geposted Sun 02 Aug 20 @ 6:27 am
was coming from version 7...the language changed...was copying things over from old version to the new one
geposted Sun 02 Aug 20 @ 8:38 pm
Would've helped if you'd mentioned that in your first post :-)
geposted Sun 02 Aug 20 @ 8:42 pm
that was kinda hinted when I said "new script language" in my original post ;)
the other 2 guys were able to understand that and were quite helpful already, but thank you
geposted Sun 02 Aug 20 @ 10:49 pm
