Hello support,
I use a Denon MCX8000 controller.
I already configured a user button with the following script:
It toggles the line in channel 3 on and off, this works perfectly.
The problem now, with the new STEMS feature, that this also disables the outer STEMS knobs (used for channel 1)
My question:
Is it possible to automatically disable (set to off) the linein 3 audio input when the fader for channel 1 is moved up from the zero position?
And, if moved to zero again, put linein 3 to 'on' again.
Thanks in advance.
toggle '$TL3' & var '$TL3' ? deck 3 linein 3 on : deck 3 linein 3 off
My question:
Thanks in advance.
geposted Sun 02 Aug 20 @ 5:52 pm
Why not assign
(I'm not sure if the deck and line numbers are correct here)
volume & param_bigger 0.03 ? deck 3 linein 3 on : nothingto the volume slider?
geposted Sun 02 Aug 20 @ 6:26 pm
FunctionGer wrote :
Why not assign
Thanks for the reply, but i have no clue where to put this script line in the pro.xml file.
geposted Sun 02 Aug 20 @ 6:40 pm
I've Googled and search this forum, and i come up with this so far:
In my MCX8000 (custom) mappings i added this line in my VOLUME Key:
It works, but it reacts to all deck sliders. I want it assign to only deck 1.
What am i missing here? Never mind.... found the solution:
volume & get_level 'deck 1' & param_bigger 0.01 ? deck 3 linein 3 off : deck 3 linein 3 on
volume & param_bigger 0.00 '`deck 1 get_volume`' ? deck 3 linein 3 off : deck 3 linein 3 on
geposted Wed 05 Aug 20 @ 2:14 pm
