Is the username for the forum, the same as the ASK THE DJ? Am I able to change the one for ASK THE DJ? Mine is Ask.the.dj./olyndtaylor. I want to change it to something a little shorter.
Thanks!
Thanks!
geposted Sun 02 Aug 20 @ 6:22 pm
geposted Sun 02 Aug 20 @ 6:24 pm
You can set up your own name, name of club or event, as you prefer.
Right-click the "ask the dj" folder and choose "set up...."
https://www.virtualdj.com/manuals/virtualdj/interface/database/askthedj.html
Dan (djtouchdan) wrote :
https://www.virtualdj.com/ask/setup.html
Thanks for the link that I already have. That doesn't answer my question!
geposted Mon 03 Aug 20 @ 12:04 am
I've gotten that far, but wasn't sure about the username in the address. So the Venue name will replace my name in the address?
geposted Mon 03 Aug 20 @ 12:05 am
If you set up another venue eg- DJOly (or whatever you chose)
Then requesters can use ask.the.dj/djoly
geposted Mon 03 Aug 20 @ 12:08 am
THAT"S what I was looking for! Thank you!
geposted Mon 03 Aug 20 @ 1:54 am
