Hi,
I would like to use an audio plugin "Slip_Backspin" that was working on Virtual DJ 8 32 bits version on the new Virtual DJ 2020 64 bits (v8.5-64 b6042).
https://www.virtualdj.com/addons/15844/Slip_Backspin.html
As i can't find the 64 bits dll version, i would like to try to do it myself...
I've tried to compile and execute this example https://www.virtualdj.com/wiki/Plugins_SDKv8_Example1.html .
I use Code::Blocks v20.03 with MinGW-w64 compiler.
https://medium.com/@yzhong.cs/code-blocks-compile-64-bit-under-windows-with-mingw-w64-79101f5bbc02
The dll executable is not compatible with Virtual DJ 2020 64 bits, i've got this error:
"This Plugin doesn't seem to be compatible with VirtualDJ 8".
Is there a documentation somewhere that can help me to compile a 64 bits dll for audio effect with Code::Blocks and MinGW-w64 compiler ?
Thanks
Best regards,
David
Thanks
Best regards,
David
geposted Wed 05 Aug 20 @ 6:29 am
Compilation is OK under Visual Studio Code 2019 Community...
geposted Wed 05 Aug 20 @ 8:41 am
you compiled for mingw32 library which is needed for the final plugin dll to work (as dlls or staticaly linked in your plugin)
The incompatibility may come from a missing needed dll in this case (see the red Note in global compiler settings), specially with debug versions
The other thing is parameter passing mode, but plugin would not detect in this case (dllGetClassObject not found)
geposted Wed 05 Aug 20 @ 4:05 pm
