Hi to the community.
i need some help to apply a custom mapping on the FX_BEATS knob on my mc4000, i try to find a solution but i'm bit stuck and it's don't work.
by default the script on this knob is dedicated to video transition and video fx but i really don't use it and i want to use this knob for the audio effects.
I going to try to explain clear as possible:
When i select and active the ECHO effect i'm able to set the strength with the fx knob but unable to set the length, i must pass by SHIFT_FX1 to modify length, strength etc...
Sometime during my gig to use ECHO and strength in same time is a bit complicate to apply the effect i want, FX more SHIFT_FX.... what a mess.
The idea is to Map the Knob beat to apply the strength, length etc when you active one effect and come back to the classic video transition when you don't use it.
Other point i must be able to use that on the left and right deck.
A great THANK for your help.
PS: this is the script from SHIFT_FX and SHIFT_FX_ON:
effect_3slots_layout ? effect_slider 1 2 : effect_slider 4
effect_3slots_layout ? effect_select 1 +1 : effect_show_gui
geposted Wed 05 Aug 20 @ 11:51 pm
