HAVE VDJ PRO, CREATED A VIRTUAL FOLDER, ADDED SONGS. DOWNLOADED VDJ 2021 AND THE VIRTUAL FOLDER IS NOT THERE? IT'S STILL IN VDJ PRO. ALSO VDJ I CAN'T GET PIONEER DDJ SB TO WORK, SAYS ASIO NOT CONFIGURED CORRECT
geposted Thu 06 Aug 20 @ 10:27 pm
The capslock button is right over the shift button, which is right over the control button on the very bottom left of your keyboard.
Do you see the same history in both versions? Did you install the correct drivers for your controller? Maybe it requires ASIO4All.
geposted Fri 07 Aug 20 @ 5:08 pm
