Topic: Precomputing Stems ??
Okay, so I see that I have the ability to "Precompute" the STEMS of each audio file prior to loading the track on deck...
my question is:
Is there a way to determine which audio files have already been scanned and precomputed and sort them in the browser like you can with Key/Bpm's?
That way if a start a batch to precompute my entire audio library and the process is interrupted for whatever reason, I can come back and sort the files that still need precomputed and batch just those files rather than having to batch an entire folder and having it recompute files that it previously completed....?
geposted Fri 07 Aug 20 @ 1:37 am
NicotuxHome userMember since 2014
The new b6059 can detect created stems
`get_browsed_song hasprecomputedstems`
and filter folder can be mapped to "Precomputed Stems is 1"
no verb to manualy create them though
unloading the track , setting precomputeStems to always, reloading the track, reseting precomputeStems to manual or precomputed
can be used as a workaround
geposted Fri 07 Aug 20 @ 1:59 am
b6059? is that a skin?
geposted Fri 07 Aug 20 @ 2:35 am
geposted Fri 07 Aug 20 @ 2:54 am
thank you
geposted Fri 07 Aug 20 @ 4:01 am
