I have been sitting down at my main computer during the Covid shutdown doing cue points and now I want to transfer all those cue points to the DJ computer.
Suddenly it does not look easy with the reading I have done.
Any suggestions or links to posts I may have missed would be greatly appreciated.
Running Windows 10 64 Bit.
The music library is on a portable SSD drive.
Thanks.
Thanks.
geposted Fri 07 Aug 20 @ 4:33 am
Database (including cue points) are one per device
if the music library is on external SSD, database stay in virtualdj folder in it
everything added to database (and to tags) are on the SSD
there should not be any issue in this case
geposted Fri 07 Aug 20 @ 4:47 am
I found the export and restore DB option, works well :)
geposted Tue 25 Aug 20 @ 6:08 am
Why though?
As Nicotux said, if all you Music is on your portable SSD just grab it, plug it into the other PC and all should be in place.
geposted Tue 25 Aug 20 @ 8:49 am
