I want to set the eq's to kill on my DDJ1000 but when I change this in the mapping the knobs are unresponsive. How do I change the eq from hardware to vdj eq's?
Thanks!
Thanks!
geposted Fri 07 Aug 20 @ 5:35 pm
the EQs on the DDJ-1000 pretty sure its just software midi knobs ...
What did you change the mapper to?
geposted Fri 07 Aug 20 @ 6:48 pm
I changed from eq_high to eq_kill_high and so on.
geposted Fri 07 Aug 20 @ 11:37 pm
You're doing it wrong. If you read the description for those EQ kill verbs, you'll see they are for muting the EQ (i.e. they are on/off switches).
Leave the EQ mapping as it is, and change the equalizerFrequencySpread config setting to Full Kill.
geposted Sat 08 Aug 20 @ 7:21 am
Ah ok, I see! I'll give that a try. Thanks!!
geposted Sat 08 Aug 20 @ 9:11 am
