Topic: Gemini SDJ 4000 VDJ Support ?
Hello Guys i want t buy the new dj controller of Gemini SDJ 4000
But can i control it with VDJ ?
I hope i can
Thanks for answers
geposted Fri 07 Aug 20 @ 8:40 pm
I dont think this one is released, so hence not available.
Will work with VirtualDJ if i remember right when/if it comes out.
geposted Fri 07 Aug 20 @ 9:03 pm
Google shows me it's been around since 2017.
geposted Fri 07 Aug 20 @ 9:08 pm
"been around" is a vague concept... ;-)
it was just prototype promoted .. first called SDJ-2000 (never got released), then re-branded/modified as SDJ-4000 at Namm in 2018... and again at Namm in 2019
And as far as I can see it still only available for "pre order" (a status it has had for a very long time)
https://geminisound.com/products/sdj-4000
geposted Fri 07 Aug 20 @ 9:12 pm
FYI, SDJ 4000 is not yet supported and no ETA at the moment
geposted Sat 08 Aug 20 @ 7:02 am
mam problem z Gemini SDj 4000. sam mi się resetuje i nie może wczytać muzyki z USB.
a po dłuższej pracy z komputerem PC i programem Virtual-DJ też się resetuje.
czy ktoś może mi powiedzieć co się dzieje, bo nie wiem czy jest sens składać reklamację.
geposted Fri 27 Jan 23 @ 2:08 pm
