Re 2021:
Sometimes Beatport Link won't load. When it does load, VDJ vanishes (as though shut down) at the point a Beatport Link track is added to a deck.
This is NOT intermittent behaviour - it happens on every occasion.
(Latest Windows 10).
geposted Fri 07 Aug 20 @ 10:14 pm
Everything works as it should here.
geposted Sat 08 Aug 20 @ 6:36 am
Try to remove Documents\VirtualDJ\Plugins64\beatport3_vdj_x64.dll and remove the Documents\VirtualDJ\Cache\Beatport folder.
Then open VDJ and login again to beatport.
geposted Sat 08 Aug 20 @ 6:46 am
How is that the expected behaviour..?
geposted Sat 08 Aug 20 @ 8:57 am
What? The expected behaviour is for things to work correctly.
geposted Sat 08 Aug 20 @ 9:01 am
Oh, you meant on your machine. I thought you meant "what you're observing is not an issue, it's supposed to be like that" ^^'
geposted Mon 10 Aug 20 @ 5:14 pm
No I didn't say that, or mean that.
You really believe that I was implying the correct behaviour to be VDJ shutting down? WHAT?!
geposted Mon 10 Aug 20 @ 6:01 pm
I kinda read it as that. Sorry, i'm not a native speaker ^^'
geposted Tue 11 Aug 20 @ 8:26 am
Don't worry about it. Your English is better than my German.
I remember in the 80s trying to translate the menus of German software for the Atari ST into English.
geposted Tue 11 Aug 20 @ 9:06 am
This doesn't seem to do it... Still same issue
geposted Tue 11 Aug 20 @ 10:50 am
I'm just going to keep using the previous version until the glitch is ironed out in next update.
geposted Wed 12 Aug 20 @ 1:10 pm
