greetings...
i have the Behringer Xenyx 1202FX....
i have the numark mixtrack platinum....
i have my PC....
im really at a loss.....i could use some direction here...
my controller is usb connected.....tho i am wondering if i should run the output rca jacks from it to the main input of the mixer ....and then run the main output of the mixer to the input of the PC......
am i on the right track here?
i have my PC....
geposted Sat 08 Aug 20 @ 9:11 pm
Are you looking to stream or, live sound? Stream, use generic drivers, not the Behringer drivers. Live, use 1/4 inputs from the controllers to the Behringer.
geposted Sat 08 Aug 20 @ 9:18 pm
apologies for delay...
yes i intend to live stream...
im in love with this mixer......the fx are awesome...
i just need to know how to make it flow with my controller and PC
geposted Sat 08 Aug 20 @ 9:27 pm
If you're looking to stream, you don't need the Behringer unless you want to use the mic. Then, the set up is a little more involved.
geposted Sat 08 Aug 20 @ 9:33 pm
yes....im using the mic......i just bought a new zingyou mic....
im a radio host......
please help me ....
please help me ....
geposted Sat 08 Aug 20 @ 9:35 pm
You need to set up the Behringer in the system OS as the mic. Then, under the VDJ sound settings, select the Behringer as a recording device. Record to file to test. Then, connec the Numark. You should be good to go after that.
geposted Sat 08 Aug 20 @ 10:05 pm
ok....im on it...
question.....
when i connect the numark mixtrack.......do i run the RCA output from it ....into the main input of the mixer ??
question.....
geposted Sat 08 Aug 20 @ 10:11 pm
