So, I've been running Virtual DJ 2018 with my Denon DN-MC6000 MK 1 (discontinued model) board. Works fine. Lately, it's been HARASSING ME to update to VDJ 2021, so I finally said FINE, I'll update if you just shut up about it. After updating, my deck 1 now is broken. It only can affect "Deck 3" which is a deck my skin can't even see. When I press play, nothing comes out, because I have a 2 deck board. Deck 2 still works as it did pre-update. I tried reverting to an old version, but the functionality remained the same - my left side only affects "Deck 3", Deck 1 won't play, deck 2 works fine. If I put in a 4 deck skin I can see the decks, but I don't want to run a 4 deck skin, I want to run a 2 deck skin. I want my old functionality back - it works! I had to go back to VDJ 7 today because it happened right as I was setting up for an event and no time to fix. Please help. I did a full uninstall of VDJ 2018 / 2021 and even deleted databases and preferences and still didn't help.
geposted Sun 09 Aug 20 @ 1:58 am
What happens, if you press the button "Deck 1" or "Deck 3" on the controller?
geposted Sun 09 Aug 20 @ 3:32 am
Are you using WASAPI drivers?
The ASIO driver for the MC6000 Mk1 had support discontinued by Atomix several years ago due to it's unreliability. They advised to use WASAPI drivers.
The MC6000 Mk2 uses a different driver and is unaffected. I know as I have both Denon models and both drivers, although, I have moved onto using Macs a few years ago which don't require ASIO/WASAPI drivers.
geposted Sun 09 Aug 20 @ 3:49 am
I guess its not a problem of the audio drivers. He wrote that he can see deck 3 is running on a 4 deck skin.
By the way: At Virual DJ settings ave found two different mappings for MC6000 (mk1):
1) factory default factory default
2) factory default Old mapping
Do you have tried both of them?
geposted Sun 09 Aug 20 @ 4:26 am
Yes, if I don't run WASAPI on VDJ 8 it won't work correctly. ASIO I only use if I run VDJ 7. But I did try it on VDJ at one point and boy was it horrible, hah..
geposted Sun 09 Aug 20 @ 5:08 pm
My controller doesn't have those buttons?
Oh yes it does!
geposted Sun 09 Aug 20 @ 5:12 pm
OK, sorry, i saw a wrong picture (from MK2). Your controller has a Deck Change Button (DECK CHG.). It will change between deck A and Deck C, its the same like Deck 1 and Deck 3.
geposted Sun 09 Aug 20 @ 5:17 pm
groovindj wrote :
Oh yes it does!
Oh yes it does!
The MKII has those buttons. I don't own the MKII, I have the original one, the older one.
geposted Sun 09 Aug 20 @ 5:22 pm
If those buttons were switched wouldn't that change the functionality in VDJ 7 also? I tried running 7 and it wasn't giving me the same issue
geposted Sun 09 Aug 20 @ 5:23 pm
Try it and press it. I wrote: What happens if...
geposted Sun 09 Aug 20 @ 5:26 pm
Yes, I know. I read your post.
Did you read the manual for your controller?
This is used to switch between deck 1 & 3 (or A & C). There's also one for the right deck.
geposted Sun 09 Aug 20 @ 5:51 pm
So, I never really knew what those buttons were for other than looking nifty with red and blue (switching back and forth). Turns out, that's exactly what happened - I did the update and must have bumped the button and it was stuck loading deck 3 forever. The weird thing though is that I would expect it to reset after closing and re-opening the program but that didn't happen, which was what made me think it was some bigger issue. Tested out my board just now and was able to switch between deck 1 and deck 3 and deck 2 and deck 4 no problem. Day of event stress prevented me from figuring it out. Thank goodness for backup laptops though, had a great event!
geposted Tue 11 Aug 20 @ 1:08 am
