The stems labels / functions have gone from my EQ column and the drop down to reselect the EQ options has disappeared.
Also I have no way to select Stems Pads either.
They were all there and working when I first updated to VDJ2021 but I turned it on last night and all reference to Stems has disappeared.
Any help will be appreciated
thanks
thanks
geposted Sun 09 Aug 20 @ 7:19 pm
Please confirm that:
1) you're running VDJ 2021 64 bit
2) the skin you're using has been updated for stems use
geposted Sun 09 Aug 20 @ 8:25 pm
I've figured it out
After the update the desktop shortcut to the previous version was still extant and I'd been launching that older version !
The new shortcut was auto tidied/hidden in a load of other ones and idiot me failed to notice.
Thanks for the time :)
geposted Sun 09 Aug 20 @ 9:31 pm
