I'm using the Gemini PMX-10 with a timecode setup, and previously I had an item in my pad drop down menu called "PMX-10" mode that I could select between hardware and software mode. This menu item has disappeared in a recent update and I can't for the life of me get it back. Tried resetting my settings and reinstalling to no avail. I know its a niche problem, but if anyone could help it'd be awesome. Please and thank you.
Dwayne
Dwayne
geposted Mon 10 Aug 20 @ 4:58 pm
With the PMX 10 connected, open VirtualDJ Settings-> Options tab ->Controller category. The setting should be at the top
geposted Mon 10 Aug 20 @ 5:17 pm
Thank you! I'll have to learn a little vdj script to put it back on a pad, but that's definitely what I needed. Thank you for the fast and helpful reply.
geposted Mon 10 Aug 20 @ 8:00 pm
But is this something you toggle regularly during a gig and u want to have it on a button ?
geposted Mon 10 Aug 20 @ 8:37 pm
