so when tabbing from one deck to the other I'm having a problem with vdj2021 cycling through all four decks. I have it set for two decks only so toggling should bring me back and forth through deck1 and deck2. Also when loading a new song to deck2 for example that deck should be the selected deck but vdj2021 just sits at deck1 - does anyone understand my problem? Is anyone else having this problem?
geposted Mon 10 Aug 20 @ 7:44 pm
And you use the Tab keyboard key to do that ?
Are you using a 4 decks controller ?
geposted Mon 10 Aug 20 @ 7:51 pm
I had that too, I remapped "tab" to isrepeat ? deck right select : deck left select
Just have to press tab a little longer
geposted Mon 10 Aug 20 @ 7:54 pm
Yes and yes, the way it's behaving it's like it's cycling thru a 4 deck setup
geposted Tue 11 Aug 20 @ 12:13 am
I just applied your suggestion and it works fairly well with the keyboard, but the controller should automatically select the deck for you once you load a song
geposted Tue 11 Aug 20 @ 12:19 am
I just got a response from tech support - within options "autoheadphones needs to be set to unload or always" somehow mine ended up as NO
geposted Tue 11 Aug 20 @ 12:39 pm
