Hello,
I recently bought the Red and blue sitcker timecode vinyls, but vitrual DJ 8 does not recognize them. I have to put them under msPinky gen2 and mess with the gain so the software can start playing. Are the Red and Blue sticker timecode vinyls an older virsion that virtual DJ 8 cannot recognize ? I am able to get the music to play and control the vinyl on msPinky gen 2 but the sound is very distorted. Do I need to return the Vinyl or do I need an older versin of Virtual DJ?
Thanks
Ahtovin
Thanks
Ahtovin
geposted Tue 11 Aug 20 @ 3:05 am
sounds like you have hw issues what audio interface are you using? I'm guessing RIAA phono is going into a line input
geposted Tue 11 Aug 20 @ 5:08 am
Could be a lot of different things. You have to give us more info.
- What 4-in/4-out sound card or mixer with a built in card, are you using?
- Are you in line or phono mode?
- What are your sound settings set up as (show a screen shot)?
- Are you seeing a perfect (or close to it) circle in the Time Code settings?
- Are you using a Pro license in your software? Your forum name shows a Home license which will either be limited or not allow DVS.
geposted Wed 12 Aug 20 @ 12:59 pm
