Hi, is there a possibility to mapp button to swap deck 1 and 3 , than 2 and 4.
Thank you.
Thank you.
geposted Tue 11 Aug 20 @ 12:24 pm
yes, at least 2 :), I've been in a techno mood recently so I'm using 4 decks [far too much] but I have preference to a 2 deck skin.
these sort of do the same[ish] thing with nuances
This one changes which of decks 1||3 is the leftdeck, I use this most often given my [edited] 2 deck skin
[might need further controller mapping, might not...]
deck left invert_deck & deck left select
this one actually changes deck 1 to number 3 [and 3 to 1] this might be closer to what you want [I use this one more for eq & fx on/off]
swap_decks 1 3
there'll be probably a bit more for your specific mapping need but it's too warm for me to start guessing, your controller, the button you'll use, specifics
swap_decks 1 3
geposted Tue 11 Aug 20 @ 12:51 pm
Using Denon Prime 4, and want to mapp it to custom button. Thanks.
geposted Tue 11 Aug 20 @ 1:03 pm
Doesnt your Prime have dedicated buttons [1]/[3] and [2]/[4] to do that ?
geposted Tue 11 Aug 20 @ 2:10 pm
Mine does, so his should too. :-)
geposted Tue 11 Aug 20 @ 3:01 pm
Yes it has, but it select them, no swap them.
geposted Tue 11 Aug 20 @ 3:24 pm
@Locodog, thank you it was what I wanted.
geposted Tue 11 Aug 20 @ 3:28 pm
I'm guessing you're sort of doing like I do, preferring centre 2 ch's for main mix and outer ch's to hold loops or perhaps even cue the next mix. I understand the work flow. when you're 4 tracks deep and maybe "in the spirits" it's easy to lose which track is which ch
geposted Tue 11 Aug 20 @ 3:31 pm
@Locodog Yapp thats it, thank you again👌
geposted Tue 11 Aug 20 @ 4:48 pm
thread made me smile:
high tier manufacturer, vdj user takes ownership and says "can we fix this?"
in less than an hour it's customised to wish-spec.
any other SW or "stand alone" , well good luck with that... a year from now, if ever.
vdj isn't a "Swiss army knife", it's a "3D metal printer"
geposted Tue 11 Aug 20 @ 6:43 pm
geposted Tue 11 Aug 20 @ 8:05 pm
