Any know why my Serato crates in VDJ have every song in twice. The crates them selfs are just normal. but click on a crate it seem ever track doubles up. When I load the Serato the crates are normal with the tracks only in the crate once. Just seem very strange. Any idea guys??
geposted Wed 12 Aug 20 @ 9:40 pm
UPDATE: this only seem to be happening on my MacBook put the same External HD in to PC it’s only showing one of each mp3 file.
geposted Thu 13 Aug 20 @ 3:05 pm
None of you guys known what is going on??
geposted Fri 14 Aug 20 @ 7:34 am
Compare the paths (using the tag editor) of the duplicates.
geposted Fri 14 Aug 20 @ 7:38 am
The paths are the same. It exactly the same file. It only Mac. On Windows the Serato crates are ok only one of each track.
geposted Fri 14 Aug 20 @ 8:13 am
Can you send* us one of the crates you get double tracks ?
BTW, Can you check if the same .crate file exists in both /Music/_Serato_/Subcrates folder in your Mac HD, and in some External HD you have connected ?
If so, can you send both ?
*Upload to any server and post the link here or PM me.
geposted Fri 14 Aug 20 @ 12:36 pm
I'm also having this issue, except on PC.
Did you ever find a solution?
geposted Sun 06 Sep 20 @ 9:54 pm
