When I try to install a skin I get the attached error.
geposted Thu 13 Aug 20 @ 1:43 am
why the hell do you want to save downloaded file to .... a protected folder ?
.... and 32bit
correct folder is %documents%\Skins\...
you may reinstall VDJ for better results...
it defines in register key:
HKEY_LOCAL_MACHINE\SOFTWARE\VirtualDJ\HomeFolder
C:\Users\<USERNAME>\Documents\VirtualDJ\
.... and 32bit
geposted Thu 13 Aug 20 @ 2:18 am
.... and 32bit
.... and 32bit
I could not figure out how to change the folder not change it to 64 bit. I will try to uninstall and reinstall VDJ now and let you know what I get.
geposted Thu 13 Aug 20 @ 2:53 am
.... and 32bit
.... and 32bit
THANKS!!!
The first time I tried it again it put it in the same place as the first time. But I wiped everything clean and went to Advanced when installing it this last time and I was able to follow that C:\Users\<USERNAME>\Documents\VirtualDJ\[/quote] path and now skins download correctly.
geposted Thu 13 Aug 20 @ 3:06 am
