Topic: Cue Loops with DDJ-SX2
Hi there,
im using VDJ 2021 with factory mapping for my DDJ-SX2. I am trying to use Cue Loops. It should work like described in your own manual for this controller:
https://www.virtualdj.com/manuals/hardware/pioneer/ddjsx2/layout/pads/cueloop.html
Actually i can switch to the cue loop page, but when i try to set a cue point it doesnt work. Nothing happens, like there is no function behind it. Tried on the controller and VDJ itself, no success. Is there something wrong with the factory mapping? How can i fix it?
Thanks,
Mexyn
geposted Fri 14 Aug 20 @ 1:53 am
can you set hotcues with the hotcue page?
Yes Hot Cues and every other function on the controller works as intended
