Topic: Reloop Touch
Hi, Has anyone used the Reloop Touch, and if so, what is your opinion of it? Did it work okay? Did you ever have any problems with it freezing up on you, etc.
geposted Fri 14 Aug 20 @ 2:39 pm
If you search the forum, you'll find at least one thread on the Reloop Touch.
Okay thanks.
It's really terrible.
Thanks Rune.
Why is it so terrible Kradcliffe?
In your other thread, you said you wanted a standalone unit. Reloop Touch is not standalone.
The mic channels are poor and distort, overall sound output is low and sounds awful.
The Reloop one is all ok ;-)
Some like cola some like pepsi .. so if you ask user X he will say this or that, and user Y this and that..
The pro reviewers and most users I've seen say its totally up to the job, and works fine. its a $500-600 ish controller, so for that price range you wont get same as a $2000 controller perhaps. It has its pro and cons
Perhaps just go by a dj store and give it a test yourself ;-)
https://djworx.com/reloop-touch/
and
