Hello.
I have the VDJ pro 8
I have Cue 1 marked as loop_in and I have Cue 2 marked as loop_out.
Do you know how you can map the software so that a loop is repeated 3 times and then automatically exits the loop?
Thank you
Thank you
geposted Fri 14 Aug 20 @ 8:13 pm
you can adapt the script in precedent post,
you can use an action cue to script the loop the same way (no need of the repeat_start loop)
cue1 action : set cnt 3
cue2 action : cycle cnt -3 & var cnt 0 ? nothing : goto_cue 1
geposted Fri 14 Aug 20 @ 8:24 pm
