Yesterday eve' I deleted 5 songs from my Music folder in Virtual DJ 8.
This morning they were back mentioned in the same folder with a red cross trough the music sign in the first column.
I deleted yesterday the music map where the song was located from my iMac.
I checked your help tutorial about it and did the right procedure but the song keeps standing there even after pressing delete.
During start up he asked me to put in my password to get the latest update. Yeah I did and maybe you forgot something to add?
geposted Sun 16 Aug 20 @ 10:06 am
bottom left, the "dot", database>remove missing files
geposted Sun 16 Aug 20 @ 10:21 am
Done.
The specified tracks are still in position with a green star in the upper right corner and the same red cross I just spoke about in my previous post in this topic.
Is it possible to remove them another way instantly or do I have to wait for a Virtual DJ update from your side.
geposted Sun 16 Aug 20 @ 10:55 am
Issue is solved:
Concluded after deleting the track from the tracklist in Virtual DJ. I had to delete the full track from iTunes library.
Than just restart Virtual DJ and the track is no longer mentioned in your Virtual DJ library.
You even don't have to restart your iMac.
Thx.
Thx.
geposted Tue 25 Aug 20 @ 6:53 pm
