faderStart and faderStop works fine in 2 decks mode
with the following issue : crossfader starts and stop decks too
but when in multi decks by default decks 3 to 6 are affected to crossfader sides)
crossfader affects ALL decks affected to left/right of crossfader
by default with more than 6 decks extra decks are not affected to leftcross/rightcross
if they manually are, they will start/stop by crossfader at the same time ALL other decks affected to the same side
what would be far better is... only left deck & right deck starts/stop with crossfader, maybe leftvideo and rightvideo too
what would be perfect is.. no deck start/stop with crossfader (because effect needing crossfader would be doable again)
geposted Wed 19 Aug 20 @ 1:50 am
this is related to the misunderstanding of the use of
leftcross and rightcross and
leftcross 'only' and rightcross 'only' and
leftcross 'none' and rightcross 'none'"
and cross_assign 'left' and cross_assign 'right' cross_assign 'thru'
which does not seems to be clear to me
and erroneous get_deck leftcross get deck rightcross giving confusing results
geposted Wed 19 Aug 20 @ 2:58 am
